I have a 1977 H33 that has developed a slow leak somewhere forward of the bilge. The only below-waterline through-hull up there is the knotmeter, which I originally suspected but have all but eliminated by drying out the locker it is in (starboard V-berth) and stopping up the drain holes for a few hours... no new wetness accumulates. The forepeak and the port V-berth locker are both bone dry. Yet I have a steady, small trickle into the forward part of the bilge. I can't image what the source is unless the hull itself is leaking somehow--which strikes me as being a very bad thing.
The boat was holed on the starboard side amidships last year; the repair site is clean and dry, and the repairman ground out and refilled the full extent of the surrounding delamination. At the same time, he epoxied a gap in the hull/keel join at the leading edge of the keel which was pre-existing (and which did not leak previously). I inspected the repairs before it went back in the water and they looked good to me. Moreover, the water forward appears to be coming in above where the hull/keel join is at, trickling in from between the liner and the forward part of the hull.
The leak is definitely saltwater, so I'm ruling out the water tank or any rainwater intrusion.
I am at a loss as to where this could be originating or how to find it. The leak rate is so miniscule that traditional ideas like tracing bubbles or overpressure don't seem likely to work. Nor does flooding the hull with the boat out of water (since I would have to flood it above the woodwork!). With the liner in the way, it's impossible to trace the stream forward to a source. Can anyone give me any suggestions how to proceed? I would prefer not to start cutting the liner away but I don't know what else to do. Even if I did so, would that necessarily tell me where the water is coming in from the outside of the hull? Or could it be following a twisting path of cracks invisible to the naked eye? Can anyone who has ever had the liner out up there comment on how easy/hard it was to pull out and replace, and what exactly I will see if I cut it out?
Any input would be appreciated! Thanks.
