Slot control
2,391
Hunter 28.5 Chesapeake Bay
Don:
I'd like to hear your views about when to open or close the slot between the main and headsail while sailing upwind in light, moderate, and high wind conditons.
Other Catalina 30 Tucson, AZ
Warren: What an interesting question, which I opened during a break in the US OPEN. I decided to have a Bloody Mary and watch the rest of the match while I thought about your question. As far as the tennis match was concerned, if tomorrow's match between Murray/Djokovic was a matched race between two Catalina 30's or two Hunter's I'd have to bet on the boat named Djokovic as the boat named Murray is going to have it's hands full.
Anyway, personally I don't pay attention to the size of the slot. I see the main and jib as one BIG airfoil that has to work together. On a masthead rig, I first adjust the jib and then adjust the main. The slot is what it is at the time of the adjustment for the current wind condition.
That's my common seaman explanation. Hopefully, RichH and Joe from San Diego can provide a more scientific explantion. Alan (Alan, where are you these days? I see you sometimes over on the Hunter site) might give his explanation as it applies to a fractional rig.
Incidently, the BM was so good I made a second one!!!
RichH
Feb 14, 2005
4,773
The probable best discussion of barberhauling (or tightening/opening/adjusting the slot distance) can be found in: http://www.arvelgentry.com/magaz/Achieving_Proper_Balance.pdf
This article was written in ~1974, long before GPS and Velocity Made Good (VMG) function. A more modern edition would be to use the GPS' vmg function when testing or preplanning the amount of barberhauling needed. The amount of baberhauling, etc. usually depends on copious previous record keeping from prior trials vs. wind and seastate conditions ... so you can 'quickly' set up the proper amount of slot open distance ...... and while making further corrections in sail shape and trim while keeping ALL the tell tales flying 'perfectly'.
What's missing in the Gentry articles is: There is no such thing as making only ONE adjustment in sail shape and trim --- always at least two 'adjustments' are required - one to make the basic correction and the second to return the sail shape back to perfect proper 'flow' of the telltales and was 'disturbed' by making the 'first' adjustment.
The 'usual' set up to barberhaul, etc. is to 'start' with the barberhauler (or transverse jib car adjustment, if you have one) IN (towards the mast) for minimal slot open distance in 'light' conditions .... and OUT/eased when in 'heavy' conditions. With barberhauling, and above a close reach you 'optimize' at the highest VMG attainable; below a close reach its all a matter of optimizing the postion of the genoa/jib fore/aft position on the rail.
As an aside, the same techniques of using GPS' vmg function are used in setting the proper jib fairlead car fore/aft position when going lower than a close reach and where the barberhauler is of NO value. I list this as virtually NO cruising sailor (and a lot of racing/performance sailors) ever adjusts their jib fairlead fore/aft position when going at less than a close reach or 'downwind'.
Joe
Jun 1, 2004
8,346
What I look for in the slot is a symetrical shape between the two sails.... and I use the main first, to get the adjustment I want, rather than barberhauling in the jib....I'll let the main's telltales augment my intuition on whether the slot is stalling the main.
If I can't fix it that way, it's time to make the athwartship adjustment.
RichH
Feb 14, 2005
4,773
With great embarrassment I overlooked the most important aspect of setting 'slot distance' or somewhat clouded the issue.
For those who dont have VMG function on their GPS .... once you feel you have all the shaping/trimming correct and when on a beat, watch carefully the luff tell tales on the jib and then steer to keep them 'perfect' .....THEN, do some adjustment trials with the slot open distance (barberhauler, transverse fairlead car, etc. etc.), ignore any 'backwinding', etc. that develops during 'barberhauling',etc. .... slowly adjust in/out the slot distance while watching your SPEEDO. The 'best' slot open distance will get you to maximum speed while beating while keeping those jib luff tell tales 'perfect' by steering.
Rx.: Watch the jib's luff tell tales and steer to keep them 'constant', and watch the SPEEDO when barberhauling.
