Sorry, didn't mean to start up a terminology discussion - looks like Nigel Calder and Don Casey call it a "radial" drive, wheel, disc or... whatever... sloppy rudder is what I've got.
On further cleaning and disassembly turns out there's a hairline crack in the top where there was minor water incursion. Many drill holes later I've isolated it to a 1x2" area in the top and it's now draining and heated by a halogen shop lamp.
I took a micrometer to the delrin bushings and there's .013" diff from side to side (vertical thickness), still need to do my math to see the slop is at 5' due to that. Of more interest is after some acetone and scrubiing treatment to the rudder stock there's definitely wear at the base of the stock about 1" above the rudder, right where the collar is at the base of the receiving cylinder.. looks like nobody used that grease fitting over the years, including me :cry:
Going to take some measurements of the diameter of the rudder stock at that point now to see what I'm dealing with but that appears to be the real source of the play (See below)
