Hope some of you guys with more experience can help me out there. I took my shoal keel 22 out to the lake yesterday and had a frustrating experience trying to make way to weather.
I sailed off the dock with a reefed main into a semi-protected channel about 80-100 yards across. To clear the channel an make the main waterbody I needed to sail to about 500 yards to weather up the channel.
I could make about 50 or so yards up the channel on one tack. Then, I would turn for the tack, the sail wouldn't "catch" close to the wind and the boat would drift through nearly a 100 or more degree turn before the boat would finally sail, then I could head up more and trim. The problem here is that in the time elapsed from initiating the turn, stalling through the turn, falling too far off the wind, and finally getting back close-hauled... the boat will have drifted down the channel and lost nearly all of the headway made on the previous tack.
I suspected we were underpowered and pulled out some of my 155 genoa until it was about the same size as a 100 (though obviously the physics weren't the same). This made the problem worse as the foresail would fill too late and exacerbate the drifting backwards. Several time we had to fall completely off and jibe to avoid crashing into the docks/shore. Think "wearing ship" in the opposite direction!
At one point I seriously considered poking around underneath the boat to make sure we still had a keel! Haha! In the end I cranked up the motor and cleared the channel under "iron sail" From there on the boat seemed to tack fine although it was much harder to distinguish how much we had "slipped" through these tacks because of the distance to any landmarks.
Any ideas? I know that it was user error and most humbly accept your advice.
Cheers,
Cheers,
