skylight replacement
142
Hunter 29.5 Lake Travis, TX
John..
Actually I didn't use the primer cause I found out about it after I finished. A suggestion about screws from Hunter was to remove the screws after the sealant had fully cured and fill the holes with 795. This will reduce the possibily of the plexiglass from cracking from expansion and contraction changes and water leaks. Also, mineral spirits is recommended for 795 cleanup. I am an architect and I think the proper application of sealants is one the least understood and misused building products even by so called professionals.
Timbo3
Sep 11, 2004
70
Hunter 30_88-94 Tarpon Springs, FL
Thanks John
Wonderful advise and thanks for the drawing. Sounds like you have some expert knowledge and it's much appreciated and welcome. I'm going to try it without screws, etc. Fred, thanks - I've had a short fuse lately. . .
