Hi, since this is my first post, I thought a brief introduction would be in order. Almost two years ago, I retired from the Navy after 22 years. I have been working in the UXO/ environmental remediation field since then. I was recently transfered to Monterey, working on the old Ft Ord. When we found out I might be in a somewhat stable work situation near the coast, my wife and I found a 1984 Catalina 27 up in Oakland. For now we are in the marina next to Quinns Lighthouse/ British Marine. The short term plan is to get her in ship shape, cruise and enjoy the bay this spring before sailing down to Monterey for the summer. The long term plan is to hone our skills before moving up to a bigger boat that we can cruise for an extended period.
When we bought the boat, everything was in pretty good shape, except for some wood rot on the port side chainplate bulkhead. As the asking price was well below book,I kind of glossed over it and didn't do a thorough inspection of the damaged area. Also, I did not hire a surveyor, figuring that it would have added 20% to the purchase price.
I had read in the forums some of the horror stories of de-mastings due to chainplate failure, and made this my 1st priority. Today I took the bulkhead and hanging locker apart so I could use the pieces as patterns. Imagine my surprise when I found out that it was glassed in. Imagine my further surprise when I pulled on it and the patch ripped away from the hull, exposing the outer layer of glass, sans core. There was quite a bit of moisture behind the patch.
My questions are:
1. How bad is it? Is it now time to bring in a surveyor? I have a suspicion that this "repair" was done by a professional boat yard.
2. Is this too big of a job for an amateur? I have some experience with fiberglass/boat building.
3. What would be the recommended repair procedure? Fill in some kind of core material and glass over that, fairing it into the existing inner skin?
4. There was a plywood doubler inside the hanging locker that the chainplate was bolted to. Is this necessary? When I rebuild the bulkhead should I stick with the original 1/2? I'm thinking of using Hydrotek from Macbeath.
5. I'm sure I'll have more questions
Thanks in advance for any advice you can give.
Nevadashawn
SF Bay Area
1984 Catalina 27
Here's a link to the picasa web album with all of the photos:
https://picasaweb.google.com/115842409165956074032/Catalina27ChainplateBulkheadHullRot02?authuser=0&feat=directlink
My questions are:
Nevadashawn
SF Bay Area
1984 Catalina 27
