Size of Shaft Packing
Feb 12, 2011
33
Allied Luders 33 Toronto
Is there a way to determine what size packing I will need before I remove the stuffing box?
I want to buy it before I start the job, and not sure if there is a rule for the size of packing according to the shaft and stuffing box nut. My shaft is 7/8. I checked Maine Sail's how-to article but there is no mention of how to get at the right size.
Apex
Jun 19, 2013
1,218
C&C 30 Elk Rapids
I believe the packing is in bulk lengths. Cut to fit when inserting. Also remember to stagger the joint positions.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
if you know the dia of the shaft and the inside dia of the stuffing box nut you can figure it out from there ......example....1 inch shaft dia....1 1/2 nut dia.....
1 1/2 inch nut inside dia minus 1 inch shaft dia = 1/2 inch divided by 2 = 1/4 packing.....
regards
woody
Feb 12, 2011
33
regards
woody
Yes, but that will be a two step process. I am trying to find out the diameter before I start, so that I can finish on the same day.
CalebD
Jun 27, 2006
1,479
Tartan 27' 1967 Nyack, NY
The safest thing to do is get some 3/16", 1/4" & 5/16" packing before you start.
Use the largest packing that fits in there easily.
Any packing that needs to be forced into the stuffing box is too thick.
Return what you don't use.
