Size of Lewmar Portlight - 1988 Catalina 30
125
Catalina 30 MKII Channel Islands Harbor, CA
Does anyone know the size of Lewmar opening portlights on a 1988 Catalina 30? I'm nowhere near the boat at present and was hoping someone might know the correct size. After checking Lewmar's site, I understand they are the OLD STANDARD but not sure if they are Size 0, Size ONE, or what. The parts list on the Catalina 30 Association's web site is for a 1980 model w/out opening ports. Need some new acrylic lenses for the things. Thanks in advance, Gary Kunkel Visalia, CA
Jun 2, 2004
1,077
Several Catalinas C25/C320 USA
C30
Try the C30 forum: http://www.catalina30.com/ Or call Catalina: 818-884-7700.
Scott
Lewmar Specs
I went thru rebedding/lens&gasket replacement last year on my 88, they are size 1(5X12). I got the part #'s from the Lewmar site and asked my local chandlery to order the parts in for me.
Jun 1, 2004
125
Thanks everyone - Size One it is!
Thanks so much. Size One is the correct part! Appreciate the input. Regards, Gary Kunkel Catalina 30 "Folie a Deux" Channel Islands Harbor, CA
Randy
c30 portlight
Scott, I need to rebed the Lewmar portlights on my recently purchased 87, per the survey. Wondering what you used as a bedding material. I was planning on using Butyl tape, but heard there may be a gasket there when I eventually remove the window? Any info would be appreciated, Thanks
