size of Hunter v berth cushions
Feb 21, 2021
6
Hunter 33 Northern Harbour
I need to purchase a mattress topper for a 1982 Hunter 33. I need to find out whether I need a Queen or double. If I knew the length and width of the v berth cushions that would be helpful. Thanks
May 27, 2004
2,059
I just re-foamed all of the cushions on my 79 H30C. I bought 'firm' foam from an American,
online foam seller, which was cheaper than Sailrite.
The company is Ritchie Foam out of North Carolina, and is online at:
"https://isellfoam.com/t/firm-seat-cushions". 704-663-2533
There are sellers out there, including Sailrite, that sell the white foam in 72" lengths.
My V berth is 76 inches long.
The "I Sell Foam" folks sell white, 24" X 80" foam, which you will need for both your V berth
and salon setees (if you do those as well).
Hope this helps.
G.
Likes: john1234
May 7, 2012
1,622
Hunter e33 Maple Bay, BC
What year is your Hunter? I may be going to the boat later today and will measure my 2012 Hunter 33 if that will be any help.
Likes: john1234
May 27, 2004
2,059
Hello "Hello"
John's 33 is the older, Cherubini version. Not sure your dimensions are the same.
Likes: john1234
May 27, 2004
2,059
John, have you decided on thickness? An OP may have changed it from original.
Feb 21, 2021
6
I am looking at a 3 inch mattress pad to sit on top of he cushions. Goal is to make the v berth more comfortable for my wife. Happy wife, happy life don’t you know. Anyway, I lan to lay the v berth cushions over the foam and trim the foam to fit. The boat is two hours away in the dead of winter. I want to make sure that pad I order is large enough to fill the entire v berth. Queen? Double? I really appreciate everyone’s help on this.
May 27, 2004
2,059
Oops, my bad. I have target fixation! :facepalm:
Well lets see... 24" wide x 2, plus 27" v berth insert =75 inches wide X 76 inches long in a triangle shape.
Get a Queen sized topper. :biggrin:
1,622
FWIW my measurements are 86” along the sides, 79” across the top and 17” across the bottom.
