sinking mast
3
ericson 32 Puerto Penasco MX
Has anyone had problems with the mast sinking on a ericson 32. I pulled the headliner back and was in awe that the mast just sits on the cabin top with only a 1"x6" piece of wood molded into the cabintop. No bulkhead used as a compression post. Any thoughts?
Apr 8, 2010
2,254
Post your question over at the main owners' site, www.ericsonyachts.org.
Lots of owners of sister ships there.
There are a ton of older boats (all makes and models) with deck-stepped masts that, over the decades, develop some rot in the plywood under the original step. Preventable with regular attention to re-bedding all the deck hardware, but sadly this is usually left for the 3rd or 8th owner to tackle. :(
If the cabin top is subsiding due to core rot, you will likely have to open it up from the top once you have the spar off. New core - use something like frp plating (aka G10) and then rebuild the surface and match the gel coat or use a matching LPU paint.
Not too difficult for a patient amateur, but it will be a learning experience. Other owners will have very good narrative and pictures to share.
Regards,
LB
