Steve Phillips
On my 1977 30' the gate valve on my sink drain line has stripped. Luckily, the valve is in the closed position. Catalina has informed me that there is not a through hull but rather a drain molded into the hull that the gate valve threads to. I remember that, while bottom painting, there are two holes. Is this the drain? Catalina feels the chances of removing the gate valve without destroying the threaded piece that is molded into the hull are slim to none. They recommend hauling and installing a through hull. Has anyone solved this problem short of hauling? Any repair or replacement ideas would be most appreciated.
