L
Larry Mongeon
On my 25' Hunter I appear to be getting a vacume effect when on a starboard tack (Sink drain thru hull side). The water gurgles from sink. Do you sail with the plug in the sink to prevent this sound? Is this a common problem with all sailboats?While I have no actual water in the boat it sounds as if I'm taking on enough water to sink the Titanic.
