About ready to put the boat in the water, but have problems with the leakage and gear shift (side controls,single lever). I'm missing a few pieces, ok missing a lot of pieces. The transmission was never hook up. There a heavy duty cable (3 times as large as a 3300 cable) with all of the end on the transmission side there and on the control side, the end has been broken off. Also the inside guts of the side mounted control lever are gone not to be found. So the questions are.
(1) were would one find a long handle single control lever and large transmission cable. I was told that you would need a long handle and large cable to move the Atomic 4 transmission lever.
(2)Do anyone out there still run Atomic 4 that has a side mounted single control handle? And do you have any pictures of it so that i can see what I'm missing.
Thank for your help and time
Shadylady
Shadylady
