- Oct 22, 2014
- 24,477
What you are discussing has affected sailors for millenia. The working boat had a destination. The course would be established by the skipper, the sails set / adjusted to keep the boat on course maintained by the helmsman (compass bearing - also what happens when you punch the AP to "auto" from standby). The only thing that disturbed this bearing/line on a chart was any water currents or underwater barriers (rocks, shoals etc.). The boat went to the destination.
Then there were sailors who just did it for fun. They would leave the dock, point the boat to open water and let the wind decide the direction.
Weather Note. There are different kinds of winds.
Sailing is harnessing the wind to try and make it do your bidding.
Enjoy your boat and sailing the blue wates of the Sea of Cortez.
- Some are formed by pressure cells. These generally are cyclonic wind patterns (think hurricane or tornado). Depending on the size of the cell and where you are positioned compared to it's center, it can feel that the wind is coming from one direction. Or the wind can appear to be gradually changing till it goes full circle around you.
- Then there are winds like the Trades. They blow not in cells but around the globe. They appear to be coming from one direction, say west, and they blow night and day steadly from the west for long periods.
- If you have a destination in mind then choose a bearing and making a direct line for that target changing the sails - triming them to harness the wind. (You can be the helmsman or you can ask the AP to do your bididing)
- If you are just out to play then chase the wind and follow it as it swirls around you.
