Natural Order of Things
Good advice so far (auto-tack feature and just centering your traveller).Taking it a little further, there's a couple approachs to single handed management of your traveller.The first one is to sail as you have been using your traveller, but leave it as the last thing that you adjust after a tack. The first things that need attention in a tack are tiller (which you might be able to attend to with your autohelm), the current leeward sheet needs to be released, and the new leeward sheet needs to be hauled in and trimmed. Once you've used all 5 of your hands and one foot to get that accomplished, THEN turn your attention to the traveller. Getting the traveller back up to the new windward side might be a bit of a chore depending upon how you are rigged, but it is doable, and it doesn't have to be done in any kind of hurry.Another non-racing single handed approach to dealing with your traveller is to make it a "before you begin your course adjustment" event. Make a mental note of the position of the traveller to windward, then ease it down to leeward until it is at approximately the same position, only on the other side of the boat, and lock in both sides. Sure, you'll lose a little sail power, but it's only for a second. Now, start through the rest of your single-handed tack: Ready the current windward jib sheet and winch handle, take a wrap off the current leeward sheet and hold it in your hand. Initiate your tack (using your autohelm if you have it, or your foot on the tiller if you don't), release the current leeward sheet as the bow comes through the wind and the sail comes over, trim in the new leeward sheet and you are set to go.One last tip about using the autotack feature - take a good hard 360 degree look as you get ready to tack, and then once again, just before you push the button(s). There's no blaming the autopilot when you snap turn in front of another boat, or tack into the course of another boat and you're distracted with handling all the lines.Good Luck!Tim BroganApril IV C350 #68Seattle
