Can you give us a hint about which batteries?
Charles
The Iota's with the IQ-4 option will charge the batteries to 14.8V then the charger drops the voltage to 14.2V for an additional 8 hours. It uses the 14.8V as a trigger point or "end of bulk" to merely drop the voltage back down to 14.2V. At the end of 8 hours at 14.2V it then goes into float at 13.6V.. If you don't use the IQ-4 the Iota's are simply a 13.6V power supply & not a true
battery charger...
Some flooded batteries may do okay with this profile but this charger should really not be used with AGM or GEL. The problem I have with The Iota is that charging to 14.8V is fine for a Trojan or some other golf cart batteries but it should be ideally held above 14.6V (temp compensated) for a while to help knock down sulfation. 14.2V is a low absorption voltage for any flooded battery and really does a poor job at knocking sulfation back. Absorption is the healthy stage of charging where we try and shed some sulfation and reconvert the sulfation but the time at high voltages even with the IQ-4 is just too short to do this effectively.
Even if you were to try and use it on an AGM like an Odyssey or Northstar, which can charge at 14.7V, and the battery was in standby, it does not need another 14.8V hit then 8 hours of 14.2V every seven days. The self discharge is just too low for this on an AGM.
The sad thing is that the IQ-4 is not programmable and what you get is what you get. The charger also lacks any ability for temp compensation...
While these are reliable chargers, they are not marine tested for UL, not programmable and have only one charge profile, and they lack temp compensation..
