A
Anthony Bavuso
Peggie,Right now I have a pretty complex plumbing system that I want to simplify. My current setup allows you to either directly pump overboard, pump into the holding tank, use a pump out station with the deck fitting, or use a manual pump to pump the tank overboard.This setup gives a lot of options but it also has a lot of hoses, y-valves, vented loops, and other stuff involved. I want to simplify all this.My new setup I plan to have all sewage go into the tanks from the head. Then have a y-valve in the tank exit line and allow switching between the pump out deck fitting, or the manual pump and sea valve to pump the tank overboard.So my question is with my new proposed setup do I need a vented loop? My head by the way is below the waterline if that makes a difference. Also what do you think of my new proposed setup? Is it a bad idea?
