Signet Depth Sounder 19E
Jan 8, 2009
33
Oday 272 Monmouth Boat Club Red Bank NJ
Problem: With the engine off the depth sounder works perfectly. When I start the engine the readings double for about 4 minuets and 19E starts to flash? The Alternator puts out 14volts charging and the batteries with the engine off puts out 12.6 volts.
Pat
Jun 7, 2004
1,250
Charlie, I think the 'E' is an error message......you can call Signet in California and they will be happy to help you....look for w/Google. Mine flashes an 'E' sometimes.....but not always... Patrick
Aug 3, 2012
2,542
You could check the power at the depth sounder to determine if you are getting a power drop or surge at the instrument. Could you also check for infinite ohms or an open circuit when the depth sounder breaker is off? I bet MaineSail could say more about this.
Thanks,
Andrew
Jan 8, 2009
33
Thanks Pat I will call Signet I was also told that I might need a suppressor between the Alternator and the Instrument ?
Jan 8, 2009
33
Thanks,
Andrew
Thanks Andrew as I told Pat I am going to call signet in California I just had this instrument in there shop for restoration but I did just change the alternator seems strange it was working great now this. Ill keep you posted.
Jan 8, 2009
33
Call Signet today and they seemed to know right away with my new Alternator (40 amp) I need to install a noise suppressor onto the power (red) cable. Stand by
Jan 8, 2009
33
I knew this was not going to be easy. There must be a hundred different noise suppressors out there. I have to call this guy again. The best I can see is a three wire suppressor but the guy told me not to splice into the line but attach it. What the hell does that mean?
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
I would expect that any choke coil filter similar to what you'd use on a car stereo would work. If memory serves, the last time I got one (at defunct Radio Shack) it was three wires. Red wires went in-line to the positive to the stereo, and one black negative to ground.
