side stays for Hunter 28.5 (bracket screws)
12
-Hunter -28.5 anderson, sc
Would anyone know the best way to replace one of the 4 screws on the bracket that the 3 stays attach to on starboard side. Is there a nut unders there or is it threaded into something within the gunnel meaning I must drill out the old screw and run a tap. I didn't see any nuts underneath. Thanks for your advice, Bob
Jun 4, 2004
844
Hunter 28.5 Tolchester, MD
Standing Riggng
I don't know what's under there and you may need to pry or cut the interior liner to find out. Obviously there is a heavy stainlesss steel rod extending past the cabinetry and down to an angle bracket glassed into the hull parallel to the length of the boat. The Owner's Manual is available On-Line and more specific responses form 28.5 owners if you try www.huntertwentyeightfive.com
