http://www.amazon.com/SHURflo-2088-422-444-Classic-Potable-Water/dp/B0006GK5NA
That is the link to the pump I have that stopped working. I took it apart, it looks clean no burns, brushes still plenty left. Bearings are fine, pump still pumps by hand, but the motor won't spin. There is a little postage stamp sized board hooked up to one of the brushes. Is this some kind of fuse that I can replace?
I installed the 3.5 gallon pump, bolted right up hoses hooked right up. But I nicked a pressurized water line with a sanding wheel when I installed new through hulls 3 years ago. The lower pressure pump didn't bust it but since I installed a higher pressure pump...I now have a nice leak to repair.
