G
George Berrier
I am looking at buying a 1986 Cal 28 and after looking at where the shrouds come through the deck I have found that there is a small block of stainless bolted under the deck and rod comes through it. Then the rod goes through a piece of teak shelf that runs along the side of the hull. Under the teak there is about a 3 inch space with a stack of washers and then fiberglass under those. Under the fiberglass there is a lug or nut that screws up on the threaded rod to tighten the shroud. The teak on top and the fiberglass on the bottom of the washers are wallowed out and you can see the washers. This makes the rod of the shroud below the deck loose. Do you have any suggestions how this may be fixed?Thanks.George
