I'm not so sure Mark . . . let's talk rig tuning
First, mast rake is set using the forestay while keeping the shrouds loose. The only tension in the forestay is the load needed to keep the mast from falling over backwards under its own weight. It's not much - you can pull the mast forward easily with just a hand on the forestay.Then the shrouds are tensioned to support the mast and keep it in place. Ordinarily, the upper shrouds are tensioned until the leeward shroud won't go slack when sailing close-hauled. This process also tensions the forestay because it s now having to counteract the aft pull from both shrouds.However, the rake of the mast HASN'T changed, because the forestay didn't stretch very much under the increased tension. Even if the forestay stretched half an inch (which I doubt), the rake won't change.If this is true, then adding a couple more turns on the forestay turnbuckle at this stage will increase its tension and eliminate the sag, but its length WON'T change, the masthead WON'T move...and the rake won't change. Why? Because the added forestay tension is being resisted by the upper shrouds. Shroud tension will go up a bit but not much, because there are TWO shrouds and only one forestay.Finally, you've probably heard me say this before but I'm going to say it again. Mast rake is not the huge deal some people make it out to be. The relative position of CE to CLR is only one contributor to balance, and it's not the most influential...mainsail trim is.Hunter mainsails are very powerful, so easing the mainsheet slightly (especially in gusts) will depower the mainsail relative to the headsail. This also reduces heeling force and move the CE forward. Moving crew weight to the windward side of the cockpit will reduce heel and can eliminate a lot of weather helm too. These are simple yet effective and EASILY REVERSIBLE adjustments and are the first things you should try because you can do them without leaving the cockpit.If the wind picks up, go to the next level. Depower the main by tightening the halyard, outhaul and cunningham, bend the mast some more with the backstay if you can or tuck in a reef, Now yo have to leave the cockpit, but again, these adjustments are easily reversible.I've learned that I can sail with a big, ugly (yet temporary) bubble in the luff of the main and still blow past boats with textbook-looking sails that were rail-down, dragging a huge wake behind a rudder more than 30 degrees off-center. The trick is to know how the boat feels when it's sailing right and trim to create that feel. Happy sailing and g'day, mate.PeterH23 "Raven"
