Shroud size/O'Day 27
Oday 28 Wichita KS
I need some shroud covers, and the boat is an hour's drive. Anyone know the diameter of these?
I also want to get some shroud turnbuckle covers. I am guessing 1 1/8 id will work, anyone know if this is true?
Thank You in advance.
Oct 2, 2008
1,424
for my OD 26, my turnbuckle covers were 3/4 internal diameter, and my spreader boots were the medium size. they were cheaper at defender than at jamestown, as is usual. if you wanted to try you hand at makiing some all they are is pvc pipe with some kind of molded cap. mine were 13 inches long.. they just do slide over the turnbuck.
maybe someone on the forum can answer the question of is the rigging larger diameter on the 27 then the 26???:confused:
