Shroud retaining clips for 1986 23
6
Hunter 23 Lake Lewisville
Can anyone tell me what the clips that hold the shrouds in the spreaders look like? I had a run in with a tree and can't find mine now.
Jim Kolstoe
possibly
First you have to remember that 3 different masts have been identified as being sold with h23s. Mine is a FranceSpar. The stay is held onto the spreader tip by a "j" shaped bolt, looks like 1/4" diameter, the long end of which is threaded with a double nut on it. The bend of the "j" captures and holds the stay in. Good Luck. Jim Kolstoe, h23 Kara's Boo.
Apr 6, 2008
6
Thanks
Mine is a different make. That is a good thing for me because if they had been as subtantial as what your describing I would have sustained a lot more damaged. I will take a look today and post the make of the mast. My sailing career is off to a rough start. I don't ever recall having a problem running into trees with my fishing boats.
Apr 6, 2008
6
Thanks again Jim
Jim, Thanks again for your response. My mast is Dwyer and the only thing holding the shroud to the spreader, by design, is a piece of wire. Thank goodness it isn't a FranceSpar. If it had been I would probably be out a couple hundred bucks instead of a few cents.
Dec 1, 2005
87
Hunter 23 Pennsville
Cmurf
Trees will occasionally jump at your boat. Seeing a tall structure with a pretty bottom, they sometimes get the urge to mate.
