Shroud Placement?
May 2, 2012
276
Catalina 310 Toronto, Ontario
I've been getting conflicting information about where the main shroud from the top of the mast goes. Here is a picture where mine is now. Some say yes some no. :banghead:Go figure. :laugh: Now let's see what we get here. :thumbup:
Cheers
2 Old Pirates
8,060
That was my first thought also, JohnVTX. :wink:
To 2 OLD PIRATES, can you please clarify your question?
Jul 14, 2015
840
Catalina 30 Stillhouse Hollow Marina
If you are referring to how is comes through the spreader, it is correct.
Nov 7, 2012
678
1978 Catalina 30 Wilbur-by-the-Sea
Are you talking about the forward lower being loose and not thru the spreader base like the aft lower is.
May 2, 2012
276
It has to do with the shrouds placement through the spreader. The Top Mast Shroud (heavier one) closer to the bow and the intermediate one closer to the Stern. Hope that is a little clearer.
Cheers
2 Old Pirates
KZW
May 17, 2014
831
Catalina 310 #307 Bluewater Bay, FL
The trees are definitely an issue.
That is how my boat is rigged.
Nov 8, 2010
11,386
The cap shrouds (the ones that go all the way to the top) are bigger and need to be on the bigger turnbuckle and chainplate at the deck. If they are, you're good.
May 2, 2012
276
Hi Jackdaw:
My concern is the placement in the sprader. Should the Cap Shrouds be in the front or back hole of the Spraders.
Cheers
2 Old Pirates
