Dr. Shrink heat gun works real well..
Scott,I have been shrink wrapping my H37C for the last 4 years. I got all of the materials and heat gun from Dr. Shrink located in Michigan.The process is time consuming when wrapping with the mast up since you have to wrap in 2 sections (mast to bow and mast to stern) and heat weld the film sections down each side of the boat and also all of the standing rigging. It takes me 2 days with my wife (depending on wind conditions). First day to mount the 2x4 wood base structure (it's marked and re-used every year, stored in the garage rafters in the summer), run the plastic rope support, install the film, seam the film and do some limited shrinking (again wind dependent). Since the fall wind here in Milwaukee normally pickup from lunchtime on, I come back early morning when the wind is low to do the final shrinking.The process with the mast down is much easier and done in a day.Where is your boat slipped or moored? I am at McKinley south section L dock and winter at Milwaukee Marine up the KK river, which allows owner shrink wrapping. Be careful some yards do not allow it anymore, so you should check with your yard.You can contact me if you have any questions (rmcdonald(@)wi.rr.com)
