Shower?
Michael
I'm a new H26 (1994) owner. Has anyone tried doing anything with a shower in the head. Of course, there wouldn't be enough water for a slow, luxurious wash, but perhaps a quick Navy shower?
Tom Wootton
Doubt it's practical...
...no way to install a drain and pump without elevating the floor because the ballast tank is directly below. Head height is already limited enough. My solution: a 5-gallon sun shower that I hang on the mast crutch. Good for rinsing off after a swim, haven't tried a full blown shower.
Ray Bowles
Mike, Tom covered all the options very well. nm
nm Ray S/V Speedy
C
Crazy Dave Condon
no shower
In order to have a shower, you must have a low place in the floor first to put a drain. Basically, the floor in the head is over the water ballast tank. That is your first major problem. Someone was talking about cutting out part of the tank to install. I can tell you the cost and manhours is unthinkable. Also, I would not recommend altering the tank itself. You can put on a sunshower as suggested. With the 260, you can add a transom shower as you have a large fresh water holding tank This I have done already. Crazy Dave Condon
Peggie Hall/Head Mistress
One more small issue...
Even if you could overcome the drain issue, do you carry enough fresh water to have enough to spare for even "navy" showers? Two people will use at least 2 gallons apiece. Two showers each is a minimum of 8-10 gallons of water--a lot if you only carry 25 gallons and it has to last you 4 days.
MARTY ALBRIGHT
SOLAR SHOWER
I HAVE A HUNTER 240 AND HAVE THE IDEA OF USING A SOLAR SHOWER FOR QUICK WASH-OFFS AND A HOT WATER SOURCE. THE BAG COULD BE ATTACHED TO THE CABIN TOP WITH BUNGEE CORDS AND HOSE LED INTO THE CABIN FOR DISH WASHING ETC. FOR A SHOWER, THE BAG COULD BE HOISTED WITH A SPARE HALYARD GIVING A FOREDECK SHOWER. NOT ALOT OF PRIVACY, BUT WOULD DO IN A PINCH TO WASH OFF. I'LL TRY IT OUT AND LET YOU KNOW.
Michael
Ok
Good answers -- all make sense. I guess I will have to sail dirty. :) Now the 260 has a lot more water than my 26 -- what is the most capacity I can add to my 26?? Michael
It's certainly hot enough here now, Marty!
In fact, be careful with the solar hot water. The temps we've been having for the past week or so can easily heat water in a bag to over 150 F. Btw...how 'bout turning off your caps lock to post. All caps is the online equivilant of SHOUTING.
Jim WIllis
Just lay a hose on the dock
That's what the "down and outs" used to do in HI before they got moved on. ALW
Steve
Cockpit shower
As a 94 26 owner, we have installed an outside cockpit shower that works well. It made sense with the pressure water system and bladder tank we had already put in. Located the hide-a-way head in the starboard aft cooming area. No leaks, water drains out, use it to wash down stuff as well. We run in salt water so it's nice to wash the OB and rudder after a day along we each other HA HA
Tom M.
pressurized solar shower
You could get one of those solar showers that have a small foot pump so that you can presurize it. That eliminates the need to hoist it up somewhere, just lay it on the deck and pump it up. -Tom
Bruce
Coleman Pressure Shower
Today in a sporting goods store I saw a shower produced by Coleman that runs on 4 "D" batteries to give you an outdoor pressurized shower. It appears that it can be hooked up to a solar shower water storage bag. Warm water and pressure, what a deal! I haven't tried it, but it looked good in the box. The price was about $25. Bruce
