Shower Sumps and Raw Water Intake
Jun 9, 2019
17
Hunter 45 Legend Warwick RI
I've a 1986 Legend 45 that has had the shower sumps removed (don't ask me why). I'd like to replace them, but am not able to find any information on them, other than the basic diagram in the manual. If someone would be able to post a picture of the installation, that would be great.
Also, the installation of the raw water intake seems odd, and a picture of that would be useful. Particularly interested in the orientation of the valve and sea cock.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
I assume you want to install a shower sump pump and plumbing as shown in the diagrams below. I have Rule Sump Pumps, but others are available at lower cost. Below is a diagram of my raw intake to the engine. A photo of your raw water intake (assuming to your engine) would be helpful to see what your concern(s) is(are).
Likes: JamesG161
Jun 9, 2019
17
Thanks for the information. You're correct in that I want to install new sumps. The forward shower pan is pretty shallow, so I'm going to have to be creative.
I'm curious to the orientation of the raw water intake because I think the engine has been out of the boat and want to make sure the installation is correct. The thru-hull is fitted to a flanged mounting plate. Then there is a 90° elbow, the ball valve, and a straight barb. The previous owner was a bit fast and loose with his repair and maintenance work, so looking for confirmation that this is correct.
Feb 21, 2013
4,638
As a chemical engineer I would not expect your raw water configuration to be acceptable IF it does not have any dog legs AND minimum distance to the engine to reduce pressure drop.
Likes: JamesG161
Jun 9, 2019
17
Engine is a 4JH-TE, with the raw water pump behind the lower right corner. The sea cock sits in that corner, but on the front side of the engine. The strainer is in the left back corner of the engine compartment, about as far as you can get from the raw water inlet and the raw water pump. That's the other thing that is prompting my curiosity.
Feb 21, 2013
4,638
Run the engine and monitor water temperature over say 30 minutes and if the temperature does not exceed the engine high temp then OK. If not, then start troubleshooting raw water strainer, water pump, heat exchanger, exhaust elbow, etc. Hate to see you haul the boat, install new thru hull closer to the engine inlet, thru hull valve and hose. Others in the forum will have additional advise.
Jun 9, 2019
17
No worries on the temperature. Engine runs very well in that respect. My engineer brain just doesn't want to accept the arrangement.
Sep 22, 2009
134
Hunter 36 Seattle, WA
And check out the Whale 320 Gulper pump for your shower sump. I replaced my OEM Jabsco with it and am very pleased with the results.
JamesG161
Feb 14, 2014
7,751
Hunter 430 Waveland, MS
I had the same thought at first.
Now I see the logic of placing the Strainer where it is visible and accessible to clean.
Noteworthy: I have never needed to clean my Engine water strainer in 5 yrs, but the rest of my strainers need cleaning.:huh:
I normally close most seacock at berth. I open the engine one, which has my keys on the handle, right before a Start up.
My exposure to crappy water, when underway, is small.
_______
I have two of these Rule Sump Pumps systems which are well designed.
Rule Shower Sump Drain System - 800 GPH
The forward head has shallow drain, but it drains aft into a collection spot. It is accessible to install one there.;)
Both of mine are on the same panel breaker.
Jim...
PS: Strainers are coarse filters and pass silt.
Jun 1, 2009
1,824
Hunter 49 toronto
I strongly recommend the Whale IC grey water pump system.
You’d only need 1 pump. Get the “T junction” version, and order the 3/4” ports
This is, by far” the most reliable and efficient solution on the market. Regular sump boxes are continual maintenance, and are built around a price.
Likes: scottdube
Aug 17, 2010
208
Hunter 410 Dover NH
I replaced both sump boxes on my 410 with the Whale IC pump. I hated those sump boxes. They smell, get clogged, switch gets gummed up and sticks you name it. The gulper diaphragm pump is much better for this job and never smells as it pumps dry every time.
Jun 20, 2020
9
Hunter Legend 45 Maple Bay
The trouble with the shower pump in the fwd head of the Hunter 45 Legend mid 1980's model is that the float switch would shut the pump off and there is always residual water left in the pan. What I did was to remove the pump, fiberglass over the holes left from the removal of the pump and hose, and I installed a drain. There is very little room below the shower pan so when you hole saw the drain hole, be carefull not to drill into the hull!! I hole sawed about a 3 inch hole so I had room to get my hand in to run a 3/4" thin wall and flexible hose under the shower pan and ran it back to the midship bilge to a sump pump box. Then I found a sharp angle 90 degree hose fitting(very tight fit for a drain elbow because not much room for a 90 degree under the shower pan as the hull is close!) that I could glue to a 4 inch piece of plastic flange and then goop and screw it down to the shower pan over the 3 inch hole I had hole sawed. Its a gregarious job- drilling a 3 inch hole into your shower pan but ya gotta do what ya gotta do!!. If any questions just write and ask me! From Al Keene. Hunter Legend 45 1987. Suzie-Q
9
And, also concerning the engine raw water intake, My strainer was located inside the engine box. Very hard to access it and keep an eye on the flow, clogging etc etc. So I moved it higher up from the water line,--- To be specific---, I put it in the aft head, outside the engine compartement, on the fore and aft bulkhead where I can SEE IT!! Its not the greatest spot but at least its accessible . I re-oriented the engine intake sea valve as well. It took some pre-planning but worth the revamp. I can provide pics if any one wants them Al Keene. S/V Suzie-Q
RoyS
Jun 3, 2012
1,742
My experience with a packaged shower sump/pump/check valve assembly was not good. In my case the sump box was small and utilized a float switch to operate the centrifugal pump. To keep the returning discharge water in the hose from re-cycling the pump endlessly the assembly contained a check valve at the pump discharge. Because centrifugal pumps have so little head pressure, often the check valve resistance prevented the assembly from functioning at all. Eventually I gave up and tossed the whole thing. Put a centrifugal pump in the shower bilge with a lighted manual switch in the shower. The light reminds me to shut it off.
