Shower Sump?
Debo Cox
Anyone got details on their shower sump project? I'm looking into one for our 1979 Hunter 30. I've checked out the store-bought versions, but it looks like I could do just as well with an automatic bilge pump, a little Tupperware, and some 3M 5200. Any thoughts? And... before someone suggests "check the archives", I'm not able to access them for some reason. Anyone else having this problem?
A
Arthur Boas
Try this neat idea
There is a product on the market called a Water Witch. It is a solid state bilge pump switch. There are also a few others which work on the same principal. Basically when the electrodes have water between them, the conductivity of the water closes an output relay. So here's the arrangement: Take a small impeller type pump with let's say 3/4" inlet size. On the inlet, plumb a short length of PVC hose tubing. Then join in a 2" length of copper pipe with hose clamps. Then another length of plastic hose about 4" long. Then another 2" copper tube, and finally another PVC tubing to your drain. The impeller pump and tubing has to sit below the level of your shower drain. Take the 2 electrodes from the bilge pump sensor, and connect them to each of the short exposed sections of the copper pipes. Now when you use the shower, just enough water will back up in the tubing to automatically start the impeller pump. As soon as the water is gone, the pump stops. You will need to put a one way valve on the output of the pump to prevent cycling from backflow. What do you think? Art Boas
Debo Cox
Cool idea Art
I've heard of the switch you're talking about - very interesting. It might be a little more involved than I want to get expense and plumbing-wise though. I can get a reasonbly powerful (500gpm) self-contained automatic bilge pump for about 50 bucks at the local hardware store. I guess you never have to worry about the switch clogging up on you with the solid-state deal - a concern with the float switch type. Thanks for the brain-power. Interesting, out-of-the-box ideas like yours were the reason I asked.
Mike
Not that this matters but...
I installed a solid state switch in my bilge last year (sorry don't remember the make). This year it was D.O.A. I was annoyed that it only lasted one year - effectively 5 months - before it croaked. I went back to a good ole trusty Rule float switch.
Debra B
Simple is OK
The setup on my boat looks simple (the tupperware-like sump, line in, and Rule pump, and a line out.) Works OK. Doesn't get a lot of use, since I use the facility at the marina when I am there....
