Shower drain hose
Sep 20, 2006
2,955
Hunter 38 Georgian Bay, Ontario, Canada
Anyone changed out the hose for the shower drain on a Hunter 38. Still have the original vinyl with the black spiral and has split from age. Not sure how to get at the hose / drain connection uner the floor pan.
Jun 17, 2022
551
Hunter 380 Comox BC
It's not fun, but doable... my arm could just reach with the floorboards removed. Heat the hose to get it on the barb. Prepare for boat yoga! It might be possible to release the elbow from the shower pan, remove the drain grate to check. Replace with the best hose possible (usually 10 or 15 yr warranty).
All the sink drains are probably due / overdue as well..... how's the exhaust hose?that's usually the first to go.
I don't trust those glued on cuffs.
PEBI
Sep 30, 2026
51
Homebuilt 35 muck
Prime example of AI slop above..... LOL. I think marine mechanic jobs are safe for now :)
Ok, fair enough.
Looking at the 2008 hunter users manual. It shows a diagram such as: Shower drain>3/4 hose> Filter> 3/4 hose> Shower sump pump> 3/4 hose run through boat hulll.
If the owner can access the sump pump could he not access the hose from the drain to the filter? Or use something to snake in a new hose after unscrewing or pulling out the old hose?
Or as you said it's possible with "boat yoga." I guess that means you did it all by touch and no sight?
From the picture of the shower sump pump, it makes the rest look easy. Is that a fair assumption?
Likes: marcham
On our boats, the sump pump is readily accessible under the head sink vanity, but the sump from the drain is actually just outside the head door under the sole in the galley near the base of the companionway stairs. Heck, almost just like the diagram.
What POs have done is lift the T&H sole and cut into the fiberglass pan below it to access the hose connection to the sump.
They didn't bother replacing the fiberglass because it was a relatively small area, the fiberglass itself didn't really support anything above it that the T&H sole didn't easily deal with.
You might try this if it works with your construction details.
That is a fair idea.
The only challenge is that hair and soap scum can accumulate in the bilge.
"Organic material (hair, soap residue, skin cells) decomposes in standing water, producing the classic “boat smell,” mold, mildew, and bacterial growth. This is especially common when shower water drains directly into the bilge rather than a dedicated sump." (Internet search for effects of accumulation in a bilge)​
Hair does not dissolve. It tends to clog pumps and screens. Soap scum acts like glue and can plug your bilge pump; the combination often leads to pump failures.
Best practice is to use a separate sump with a dedicated pump that you can clean out from time to time.
JamesG161
Feb 14, 2014
8,108
Hunter 430 Waveland, MS
On my H430 there are 3 inputs
1) Shower Drain
2) Lavatory Overflow
3) Refrigerator condensation
Jim...
PS: Output is on the Red Pump discharge
PEBI
Sep 30, 2026
51
Homebuilt 35 muck
Direct quotes from the 2008 hunter manual.
The shower drains into a sump pump which keeps hair, soap scum, and bacteria from building up in the bilge and developing an odor. Periodically clean out the pump filter to prevent clogging the pump.
10.2.3 Shower Sump
Due to the level of the shower drain, we have installed a pump system to rid the boat of water from your shower. The small holding tanks also acts as a collection point for hair and other waste materials that might get washed down the drain.
Similiar to Jim photo.
I am curious what cleaning "solutions" do you guys use to clean the filters of soap scum, hair, skin cells, and the like from the shower drain?
I read the manuals of several "toilets" that flush directly through hull. They said not to use common cleaning supplies found in store.
I assume that means white vinegar and bicarbonate?
Not necessarily vinegar and bicarb.
Cleaning the sump can use dish soap. Yup, simple stuff. Dish soap, Joy or better yet Dawn, is great for many boat cleaning chores. Nothing "marine" related is needed.
Toilets on boats are different because they are not like household toilets. Please, think about it, they do not go to sewers do they?
Buy Peggie Hall's book Boat Odors, available here on this site, and learn about the head systems and other issues you are dealing with.
Good luck.
PEBI
Sep 30, 2026
51
Homebuilt 35 muck
Good luck.
I only meant that I read up on heads (manufacturers) and they don't use common household cleaners. (I have seen household cleaners laying around in boats for sale).
I did not mean for you to interpret what I wrote as using say clorax to clean a shower filter.
Dish soap works better then carb and vinegar. Go figure.
Sep 20, 2006
2,955
So, I never knew it would come out like this. Our H33 the grill was stuck down solid, probably caulking. This will be easy to replace.
