Showe Hose
542
Hunter 33 Seabrooke, Houston
Looking for a shower hose for my H33 (82)
It has on both ends a fitting that is 1/2" on both sides: the thread is on the inside, and it screws onto the shower end on one side, and on the fawcet at the other end
Seems quite an easy thing to do, but have not been able to find
Looking for about 6 feet of it
Any idea?
Recentlygot new fawcets (kindly assisted by a member) and now I want to replace the hose
I await with bated breath...
Dec 2, 1997
9,010
- - LIttle Rock
I think you can find what you're looking for in...
The plumbing section at Home Depot or Lowes. If not, try an RV supply store...shower fittings would be same for RVs as for boats.
Jun 21, 2007
2,118
Re: I think you can find what you're looking for in...
Hi Jorge:
I recently removed a hand-held shower attachment from one of our home bathrooms. It occured to me that the hose looked better than the one on my boat.
It was a direct fit. The threads are standard ... exact same as for a home shower head. Peggy Hall is right ... the plumbing section of your local hardware store should have something, although you might need to buy a complete hand-held conversion set just to get the hose. Or maybe you can fabricate your own hose out of miscellaneous fittings from the plumbing section.
rardi
Mar 21, 2004
2,175
Hunter 356 Cobb Island, MD
Just replaced my about three weeks ago. Everyone is correct go to Lowes or Home depot it was a direct replacement...
Jun 25, 2009
542
I'll be damned!
Seems easy enough; the Home Depot I went to was a small one.
Will try local hardware store, RV place and Lowes
Thanks
Jorge
