25.5 shorepower
Mine is in the same location discussed by Charles. The wiring then runs to a breaker on the main panel. The wiring then goes to individual outlet boxes located on the port side of the engine compartment, on the shelf areas near the main bulkhead (each side), one on the aft portion of the starbord shelf (immediately forward of the galley area), one in the head sink enclosure, and one in on the V-berth bulkhead immediately forward of the head. This was an apparent overkill, but the system works well. The bulkhead outlets are installed in normal orientations. The outlets on the shelf areas in the main cabin area are installed facing upward. If I used the shorepower more, I would not like the potential for these upward facing outlets to catch spills and short, but I have had no problems with the limited use I have made. The wiring is located within enclosed compartments and under the main cabin shelving. Well hidden and looks easily installed. A ground fault protection device is installed in the system.
