I got a request from a member for more details on the shop cradle I built for my C22, so here are some more pictures and details of materials and measurements.
Notes;
- I built this to hold the C-22 INVERTED. The design can be easily modified to hold the hull upright as well. Heck, it may work just the way it is without modification but I haven't tried. Wouldn't that be a hoot? The big thing to remember if you try this, the aft portion of the hull is thin and flexible. The aft cradle section would need to be modified to spread the load as much as possible to avoid point loading and cracking the GRP.
-These dimensions (especially where the pads land on fore deck and in cockpit) are for my 1982 C22... So if you have a 1986 or later C22 you may have to check and possibly make changes.
- You can use heavier lumber if you like. Just don't try going lighter with all 2x4 construction... trust me. It gets too flexible in key areas. You will see how I added strength in key areas.
- Its not very expensive even if you buy all new lumber. I don't remember exactly but I know I spent only around $100 on the first load of lumber, I added a little more later so it was only around $120 max.
- It is a 3 part design so it is easily disassembled and stored or moved in a pick-up truck. If you nail or screw the whole thing together you are stuck with a big, awkward thing that will be a pain to deal with when the boat is back on the trailer. The Fwd and Aft sections simply bolt to the middle section with 3/8" grade 5 bolts. It takes just 10 minutes and a helper to put together or take apart.
- You need GOOD quality, HEAVY DUTY caster wheels with ball bearings! Its pretty heavy, probably around 1300 to 1500 pounds of boat on the cradle with the keel off, even more if the keel is on! With good caster wheels, on level ground, one person can roll and swing this around with the boat on it.
Notes;
