shol keel spec's
K
ken
Just bought a O'day 25 with centerboard. I need to modify (raise) the bunkboards on my trailer that used to haul my Catalina22 swing keel. Can someone tell me the exact measurement of the shoal keel that came with this model so I can raise the trailer bunks the correct height. Thankyou in advance. ken in sacramento
I
Ira
The same
Ken, We have the same O'day 25 (1977) with swing keel centerboard. I need to modify the bunkboards on my trailer too. Hope someone can give you exact measurement of the shoal keel that came with this model so I can raise the trailer bunks on my trailer too. I am modifying an old camper trailer. Thanks, Ira
H
Herb Parsons
Centerboard Keel
I have a '76 O'Day 25 with a centerboard (it IS a centerboard, not a true swing keel). O'Day lists the depth of the keel with the centerboard up to be 2.5'.
Mar 26, 2004
36
Oday 25 Salisbury, MD
Oday 25 Keel CB measurments
Here's a picture with some measurements that I took of an Keel CB 25 for modifying a trailor. Bottom of Keel 11" wide. Bottom of keel to hull 14". Keel to curve of hull.. about 35"
Mar 26, 2004
36
more Oday 25 Keel CB measurments
Side view of keel measurements. Begining of keel curve at hull to bottom edge of keel 29". Keel bottom from forward bottom edge aft 80"
Jun 2, 2004
1,438
Oday 25 pittsburgh
Keel on the trailer
Ken, Unlike the Cat 22, the keel/ centerboard housing should rest on the bottom frame of the trailer. I have owned 2 O'Day 25's and had to dosome work to each trailer. My suggestion is to let the keel rest on the bottom frame and then adjust the jacks, bucks or what ever your trailer has. The location of the boat fore and aft of the positioning of the boat on the trailer will affect the height of the pads/bunks whatever. A picture of your current trailer would help me give you ideas for fitting your 25 on the trailer. I do have pictures of some mods. that I made and pictures of what to be carefull of. I just don't know where they are and time to find them. r.w.landau
