Shoal or standard Keel on the Hunter Legend
V
Vincent
I'm considering upgrading to the 37ft. Legend. This model is offered with a 4foot bulbed & winged keel or a standard six foot keel. HOw much difference will there be when going to blue water?? Does the wing and the bulb make up for the lost length??
Paul Akers
Tough question...
I have a bulb-wing keel on my L37 (4'9" draft) and have had no problems with sailing it. I've never sailed the fin keel (6' draft), so I have no comparison other than to say mine has performed well. The basic advantage that I can see is that you can sail in thinner water. Six feet can be a lot for some of the nooks and crannies in New England waters.
G
Greg aboard "BlueBerry"
six feet under...
your keel is a lot to have there all of the time! I am currently lake sailing, and certainly have to be more concerned with my 6' keel than if I had the shorter bulb keel. However, since i have not compared performance I cannot say that one is far superior to the other. Although it may limit you slightly in some sailing areas, I would not let that be the sole determinant of my next boat purchase.
Del Wiese
great boat with either keel!
I have an 89 Legend 37 with shoal draft which is best for Florida/Bahama cruising. I suspect the deep draft will point better but that either has similar stability. I am sure there is a design parameter that measures the stability, the resistance to heeling for given wind speed and sail configuration. I am sure the bulb/wing on the shoal draft is an effort to provide similar stability and pointing to the deep draft. Maybe Hunter can give you design details. No matter which keel, the Legend 37 is a great boat!
C
craig
shoal vs deep
We have a 34 with a shoal and our friend in the marina runs us off the river with is deep draft same boat. he points alot higher but gets stuck in the mud so we have to tow him out. go figure. craig
