Shoal Keel Problem
3
Oday 22 S. Paris, Maine
There is a small crack on the bottom of the keel caused either by a buonce on a rock (or other hard surface) or water in the keel freezing. It;s been there for years and doesn't leak much but my wife is concerned. In the interest of marital harmony I have determined to fix it and need to decide between two methods: 1. To grind out the crack and use epoxy filler, etc. (or) 2. To mix up some slow setting epoxy and pour it into the bilge until it begins to drip out of the crack and then use a plastic covered board to keep it in there until it sets. Has anyone ever dealt with this problem or can offer advice? I'm kind of attracted to #2 because it seems easier and would bond any other delaminated areas.
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
Sea Bear
I did a simalar repair on my ODay 32 with a shoal keel and I put a solvent in the bilge first and let it weep out and dry to clean the area then I duct taped the vac hose over the crack to pull the epoxy (WestSystems) out, worked like a charm
May 28, 2006
3
RAD
Thanks RAD, Sweet joy! At last a fix that won't require extended contortions!! What solvent did you use? Acetone? Alcohol? Both?!? Now I just have to wait until the snow melts...
K
Kevin Walsh
Common O'Day 22' Problem
Sea Bear, this is a very common problem with O'Day 22s. If you search the acrchive, you can find a lot of info on this issue. I recomend you don't waste your time with a quick fix. It won't last. I made a few of those quickies that didn't last. You didn't have to hit a rock to cause the problem and freezing didn't help either. It is a weak part of the design of the boat and it happens on boats that never went aground. I recomend you get some fiberglass mat and some cloth and some poyester resin. I used a belt sander to remove the bottom coat and to get down to the orginal glass. My crack went from beam to beam at the point where the forward part of the keel meets the hull about a foot long or more. I couldn't see all of this untill I remove the bottom coat. The crack also went around the top of the keel. Latter I found the huge blister on one side of the rear of the keel. The aft corner was repaired where it almost broke off. I think I have a wet keel and the winter here in NY can be brutal. I put lots of mat at the front of the keel and extended the point of keel/hull joint forward about and inch or so the that the greatest stress would be forward of the origanl crack. The hull is now twice as thick or more than the orgianal hull. I finished off the glass with cloth. It is all very smoth and the thickness I created in that area in not really noticable. I then took the boat out in 25 mile an hour winds and high sea state on the hudson in october. I got my ass kicked because I was solo, but no problems with the boat. I don't get to this site very often. If you have any questions, I can be reached at turtlecove@taconic.net Good luck. Kevin
