Shoal Draft O'Day 22 I recently purchased a 1977 O'Day 22 with a shoal keel. Does any one have any specifications on this model 22? I do know that the standard specs I found do not correspond to the actual specs of the boat. For instance, the mast is supposed to be 27ft long, but mine is only 23'-6". I just purchased a new main sail, and purchased is by my measurements, but the sail loft sent me one to fit an O'Day 22 and it is the correct luff lenght - 20'-3".I am not sure how much the boat draws? I measured about 30" but that is based on the waterline stripe that the factory put in. Is this correct. I am going to need this information when I put in. There is a lot of shoaling in the area!I have a 15 gallon water tank in the bow under the V-berth. Is this standard? The only fill I found was on the top of the tank which is as un-handy as hell! Has any one made a modification to allow for filling from the deck?Is there a bilge in the boat? I found a small opening in the aft section of the cabin, about 2" in diameter. It is the only place I found any opening to get to the ballast area. It is too narrow to put in a bildge pump, but I need one since the boat will be in the water. I hate to put one in the cabin, that's like "locking the gate once the horse has bolted!"I am in the process of extensive remodeling, and not neccessarily to original specs. Most of it is on the inside, but I did have to change the ports. They were broken and the plastiglass had "spidered!" I "sandwiched" the cabin with two pieces of smoked plastiglass about 6ft x 9". It works great, but I had a lot of sanding to do to make the original opening presentable. It can be seen throught the plexiglass. See the photo that is attached. It makes the boat a little more modern, if you are not a "purist." I am a "functionalist!"If there is any one out there that can help me with my questions, I would be greatful.
