shifter cable for beneteau 38
19
Beneteau 38 Slidell
Hey I just got a beneteau first 38 .. sails great. I'm going to have a lot of questons.. The shifter cable on the perkins 4 108 broke and the engine is stuck in reverse. boy it was great getting into dock. That's another story.. I got the cable out and I'm looking to replace it. Anyone know where I can get a purchase a new cable?
Jun 16, 2005
476
- - long beach, CA
Try customer service at Beneteau
or the maker of the pedestal. Check Defender, too.
Brian B321
Beneteau Customer service is fantastic
Just wanted to hijack this thread and give full credit to Todd at Beneteau customer service - I had a plumbing issue at the hot water tank - He Emailed a diagram and picture of the part - and the service was immediate - Wow! Todd Cranford - Customer Service todd.cranford@beneteauusa.com 843-629-5300
Randy
cables
Your First 38 probably has the same cable configuration as my First 42.. Broke a cable myself, there should be an inspection area in the quarter area to access the side of the trans so you dont have to go over the motor.. Pull the cable and take it down to the local marine store.. Its pretty common fittings on the ends.. measurement can be off by being a foot over sized but cant be shorter.. you also have the inspection area in the quarter to get that cable up the tube to the shifter. took me a good hour to replase the unit on mine.. just a note.. I've replaced the cable to the 4-108 at the same time. to access the screws on the end of the cable under the intake at the pump.. just un-bolt the bracket at the back of the motor that holds the cable.. it all slides out the rear and you can work on it off the motor... Over the past few years I've replaced almost everything on the boat to get it ready for a 5 to 10 year trip out.. give me a shout directly if you need any assistance and cant find it elsewhere...... Randy - sailingonr3@yahoo.com
