Shift & Throttle Cables
Timbo3
Sep 11, 2004
70
Hunter 30_88-94 Tarpon Springs, FL
Need to replace shifter cable: Anyone know what length? Edison pedastal, Kanzaki trans.
Also need to replace the Throttle cable while I'm there, again: Anyone know what length? Yanmar 2GM20F engine
Finally, anyone know if I need to remove the pedastal/binnacle to get to the underside to replace these cables?
Thanks,
Tim
Oct 29, 2005
2,362
It shouldn't be too difficult to measure. Just err on side of caution and have it longer rather than exact or shorter.
Jan 29, 2010
15
Hunter 30T Solent, England
Replaced ours 3 years ago. Fitted Teleflex 33C TFXtrme (16ft long) for both throttle and gear. (Hunter 30T)
Oct 17, 2011
221
Catalina 310 USA
Thanks,
Tim
curious, why do you need to replace it? What issues are you having?
My shifter seems to be very difficult to move in and out of gear and have been looking for a solution.
Timbo3
Sep 11, 2004
70
iSailor, my shifter was stiff, then broke while on a week's cruise. Broke in the pedastal, the threads snapped at the end fitting. Trying to rig something that I could shift with, I cut it down piece by piece (nothing worked) until I had to remove from the trans all together and run control ropes through port holes to operate the transmission (very Jed Clampet). While investigating, discovered the throttle cable housing is totally rotten and will be next to go.
Timbo3
Sep 11, 2004
70
Phoenix, what did you do for cable ends? Also do you have to take the pedastal/binnacle off?
I have an Edson pedastal, Kakzaki trans, Yanmar 2GM20F engine.
Hunter Inc or Hunter Sailboat owners can't help. Kind of dissapointing.
Timbo3
Sep 11, 2004
70
pics of trans cable and bracket
Here are 2 pics of each end of the trans cable. The rusty old bracket is a part of the remote shift kit that was istalled (shifter lever), but is not referenced in any of my manuals and the Yanmar shop has no idea where to get a replacement. Sailboat Owners is at a loss to. . . hope I don't have to fabricate one with the cable housing stop.
15
Timbo3,
In my case the the previous owner had simply cut the cables as they exited the Pedestal! and installed another control system on the cockpit bulkhead. I presume this was the easiest solution at the time.
I wasn't happy with it so set about restoring the controls back to the pedestal when we bought the boat. I had to remove the complete pedestal inorder to route the cables through. There is a small hole in the bottom plate and i found it impossible to pass the cables up from the bottom withiout fouling the steering chain assembly.
The brackets on the Yanmar 2GM20F were OK on our engine so I could simply attach the teleflex to them. On the pedestal end I bought Edson control kits which included the stainless levers etc and came with the clevis pins for cable connections. Edson kit here: http://www.edsonmarine.com/marinestore/index.php?main_page=product_info&products_id=1083
Shaun.
