Shift cable and fuel / throttle cable
eusjim
Jan 7, 2007
5
Hunter 34
Having just replaced both throttle cables, wanted to share the correct part numbers of the shift and throttle / fuel cables for my 83 hunter 34. Both are standard 11 foot long Teleflex CC17211 3300, available at most marine supply houses.
I have read that it is easiest to remove the pedestal. I didn't. Lot of work, but nearing completion. Prior cables were the same part numbers.
:dance:
Hunter 34 Alameda CA
Thanks Jim. That task will be coming up soon. I'm currently waiting to see if I can get a replacement for my plastic contol head where the two levers are mounted. A machine shop is trying to replicate it, but it is low priority right now. How cracked is yours?
Dec 14, 2003
1,446
Thanks Jim, I replaced the fuel cable a few years ago but was dumb enough to discard the number and the invoice. Alan, you can order a Merriman Aluminum shifter Lever box from these folks:
Robert Osaki
Joes Racing Products
1410 80th St. SW Unit F
Everett, WA 98203
office: 425-267-9199
email: robert@joesracing.com
I ordered one 2 years ago (+/-$160) and was totally satisfied. I had it powder coated white and it is a great match for the pedestal.
119
Hunter 34 San Mateo
My mechanic swears by Volvo so I bought an 11 and 12 foot Volvo cable. The transmission cable is a foot longer, because of the loop over the engine. At the beginning, I manually ground some of the lever box since the lever was limited in how far it could go because of the lip on the box. Second, I loosened the bracket holding the throttle cable against the interior aft position of the pedestal too much and it fell down to the bottom. However, I bought a 4' wood wand from Home Depot ($.88), went one night with a flash light and poked it through the steering cable outlet and it came right out, after about 5 minutes. I had one guy in the marina try to convince me to take the whole pedestal off to get at the piece and my mechanic tried to convince me to buy a specialized grabber to get it. This sort of thing was like an intelligence test. Who is the biggest idiot in the marina. Me for causing the problem or some people who come up with these ridiculous solutions?
Now, how do you get the bracket back on there? Well, it's rounded perfectly to fit my nice wooden magic wand and I used one long piece of electrical tape to secure it in place, and then candy caned the tape up the rest of the wand. Carefully, placed the bracket behind the screw and in it went. Pull the tape off as one long piece and use another wand to poke it a bit, and out it came. A surprisingly annoying thing was to get the throttle cable back into the bracket because of the angle it comes into the pedestal from below. That took about an hour or so to get right. Everything is back on and in it's place, except I now have to buy a throttle cable clamp because the throttle on the engine is designed to fall back (or at least that is what my mechanic tells me). So now I have to find a clamp to put on the cable so that it sticks in position. As is most things on the boat, this took about 5 times longer than I had originally expected and turned into being way more complicated for what should be a simple thing. Yes, I know everyone makes it sound like it was lickety split, but, at least for me, it wasn't. But a good education though.
Dec 2, 1999
15,184
I am not sure of your exact issue but we just used a small hose clamp on our stop cable. It has worked for over 15 years.
Apr 5, 2011
113
Hunter 34 Tilghman Island, Md
In the pedestal, does the throttle cable get clamped into the detent towards the end of the cable? Replacing mine right now and when I do that the cable end won't reach up past the wheel spindle. I'm beginning to think it was just clamped onto the cable. That means that it would have acted as a cable brake.
Thanks
Apr 20, 2010
119
Hunter 34 San Mateo
Not sure about detent since the Soviet Union collapsed. But I'd be careful using the bracket in the pedestal as a cable clamp to prevent creep in the throttle cable. I have a 1984 Hunter 34. My bracket was clearly weathered and not as strong as the cable clamp I put in today. Something sounds wrong it your cable can't make it past the wheel. Use the bracket in the pedestal to position the cable away from the steering cables.
