I was running my Universal M-18 equipped with the Sherwood Raw Water pump this past weekend, checking all my hoses, clamps and other fittings readying for the spring. I noticed a slight drip, drip, drip, coming from under the Sherwood Raw Water pump impellor housing (about an 1/8 " hole). I was not sure if this was for pressure relief which helps from keeping that light paper gasket on the face plate from blowing.
I saw the schematic of the pump and noticed a 1/8" NPT brass screw in "drain plug" but I failed to feel for any other plug after I turned the engine off.
Do the raw water pumps, specifically the Sherwood weep water? Or do I indeed need to buy the replacement plug?
Thanks
Bob
1988 Catalina 30 Mark II
Thanks
Bob
