260 jib sheets
Rick, welcome aboard! I have a new 2002 Hunter 260. I have the same problem with my jibs sheets. First thing I did was buy a LONGER jib sheet. The one one the boat from Hunter is way short. As someone posted earlier, as a man I find that I can hold all sheets in my hands and do not need wenches. But I sail with my wife and there is no way that she can. The second thing I found wrong with the 260 is that they have out two rope clutches on the port side and one clutch on the starboard side. Port side clutches are for 1) Center board and 2) Jib Haylard. Since I have a roller furling jib I don't need a clutch for the jib haylard (but I use it anyway). I have re-run the center board line from the clutch thru the cam and to the cleat on the port side, thus freeing up one of the clutches. On starboard side I have run the Main Haylard thru the cam and tie off to the cleat, thus freeing up the starboard clutch. Now with one clutche free on each side, I ran my jib sheets thru the clutches. I am miffed at way Hunter has run their sheets , cams, and clutches the way they have. I think that they need to have two rope clutches on either side. I plan to do that myself. By running the jib sheet thru the clutches it is a lot easier for my wife to work the jib sheets. The only problem which now arises is, I do not have the second clutch on the starboard side for my main haylard. I understand the problem with trying to use the rope cams. They are too far forward and make securing the sheet very hard. But since I use the main haylard alot less the the jib sheets, it's a small price to pay. And my wife is a lot happier, and that's what counts. If any thing I think Hunter should have the double clutch on the starboard side and the single on the port. But what do I know? I love my Hunter 260 and with minor changes we will make it work. BLUSKIES & HIGHTIDES...rb
