sheaves
15
Hunter 34 traverse city
I need to rebuild my cabin-top traveler and need four sheaves that are 2" OD, 5/16" ID, and 9/16" thick/wide. Does anyone know where I can find this size sheaves?
Jun 2, 2004
5,802
Try Rig-Rite.
Check the Related Link under "Sailboat Hardware". If you don't find it call them anyway, maybe they can direct you.
Jun 1, 2004
227
Beneteau 393 Newport
Who makes the traveller? I have a Lewmar and have found it to be inferior to others I have used in the past. I find Garhauer to be a superior product at a very reasonable price. http://garhauermarine.com/index.cfm Jim
flyhop
Aug 8, 2005
150
Oday 28 Guntersville AL
Sheaves, etc
I have had some recent experience with Rig-Rite. Some of their office space got burned up in a fire, and they are operating almost exclusively by fax. I called them last week, and their phone was still out. Last I got a quote from them, I did find them to be rather expensive. But if you have to replace a sheave that is hard-to-find or not-made-anymore, then you may not have a choice. I would contact Schaefer, Garhauer, and Ronstan directly and see if they don't have a replacement for you. You didn't describe your problem with the sheave or traveler. If it's Delrin (Acetyl/hard plastic) and it's fallen apart, then you will have to find a replacement (that happened to 2 sheaves on my boom vang...buying a new vang was cheaper). A traveler probably wouldn't have aluminum sheaves, but if that is the case, talk to your local machine shop about fixing. BTW, when you call around, they will want to know if the ID is the bushings ID or the sheaves ID. Good luck with your project.
Jun 16, 2005
476
- - long beach, CA
traveler
zz; Google "Garhauer". They're located in Upland, So. Cal. They make good stuff, their prices are right and they'll customize, too. You can't beat them.
May 22, 2004
130
Other CS27 Toronto
Have you checked a marine store?
The rigging shop I deal with has catalogues for all the manufacturers and based on the measurements will try to look up and order a match. If that doesn't work for you I agree with Larry W. Garhauer can probably sell you a whole new traveler for not much more than the 4 sheaves will cost you. Kevin
