I got a problem, I think I sheared the key on my prop shaft in the shaft coupling and my shaft backed out (moved aft) about an inch. I think I need to replace the shaft coupling and key. Help!
Background: I've got a Yanmar 2QM15 (C&C29) with a PSS shaft seal. Earlier this summer I remember hitting a log or line while motoring as evident by a small nick in my 14" bronze prop. Last weekend, while motoring back from a trip, my PSS shaft seal developed a serious leak. A temp fix got me back to dock. Today I examined the issues and found that it appears my 1" shaft has slipped back about 3/4", compressing the PSS bellows.
Here's the main problem/indicator: I can rotate the tranny & shaft couplings 3/4" left and right before it starts to spin the prop shaft. I know that's not good. I'm sure the couplings should be positively attached to the shaft with NO leeway or slippage. The set screws on the shaft coupling are still wired and don't appeared to have backed out.
I think I snagged something with the prop, got the nick in the prop and the strike sheared the shaft key in the shaft coupling. This loosened the shaft in the coupling, allowed it to slide out and aft a little, caused the leak in the PSS seal and that's why there's play between the couplings and the shaft.
Any thoughts, ideas, suggestions? I have to fix this DIY as money's tight. Since the coupling's loose, with play/slippage, it should come off OK so I can replce the key. Should I also replace the coupling? Mine is not a split coupling but a solid one.
Thanks
Kevin
Thanks
Kevin
