shallow water sailing
Sep 25, 1999
600
Hunter 23.5 Indian Lake
I am running into some areas where my centerboard on our 23.5 is hitting the bottom . Whats the consensus on having the board partially down ?
May 24, 2004
7,202
CC 30 South Florida
A centerboard has no ballast and its sole function is to help the boat steer into the intended course by minimizing lateral drift. It should be perfectly safe to operate the boat with the centerboard all the way retracted or partially retracted.
Jun 6, 2006
6,990
In fact you should raise the center board when sailing down wind to reduce water drag!!!
welcome to gunkholing
-na -NA Anywhere USA
Gunk holing which many to include me have done. One thing to mention though with the board partially up, you will slip sideways more but in light to moderate winds is ok but concerned with heavy wind when the boat is heeling and slipping a lot.
