Shakey shakey Prop Mystery -Hunter 34
Nov 26, 2012
1,654
C&C 40-2 Berkeley
I have a mystery. Recently a crew member slammed the tranny into gear while it was running fast. Instant heavy vibration. I had my diver remove the Martec folding prop and put on the fixed prop. Upon inspection of the Martec prop it appeared to be in perfect condition. The vibration with the fixed prop is different but still there. When the engine is first started there is some squeaking from under the boat but relatively minor vibration. This only happens while in gear. Reverse or forward. After about 10 minutes it gets bad. The engine shakes like an out of balance washing machine at about 1500 rpm. I pulled the boat and there is no obvious sign of damage. Nothing loose. No visible bend in the shaft. A small amount of play in the cutlass bearing.
Does this sound familiar to anyone?
pateco
Aug 12, 2014
2,207
His slamming it into gear may have shifted your motor mounts. Have your shaft alignment checked.
Nov 6, 2006
10,247
And check the mounts as well. The shock may have torn the rubber loose from the steel in the mount
