Sounds like you have a "hot" marina
It seems strange to me that you have to replace 2 zincs after only 8 months in freshwater (that's an assumption, since you live in Salem). Sounds like a neighbor of yours is shooting off stray electolysis and that's eating up your zincs.A galvanic isolator? I'm guessing that's one of those zinc fish you hang off the back of the boat. The only way those things work is if they're grounded to a bonding plate. The other alternative is to bond every metal thing on the boat, including standing rigging & stanchions. Then you can just hook up the fish to a stanchion. But don't attach it to a stanchion unless they're bonded, otherwise your prop will be cheese in a year!One more alternative is to find another slip. Where's your boat moored? Here's an example: my guy's C30 was in Tomahawk Bay in Portland. He hauled it for a bottom job and then over a year later he hauled it for a survey to sell it. The zincs were like new! If you're in Tomahawk Bay, you might consider moving slips & see if that helps (assuming a neighbor has stray electrolysis). Good luck!LaDonna
