shaft woes
t-bird
May 23, 2009
1
2 c-30 san fran
Im having problems diagnosing my prop shaft wobble. Heres a bit of recent history: After hauling my '78 Catalina 30 I motored back to dock for 3 hours. Everything went smoothly. 2 days later I went out sailing and on my return I noticed vibration then,bang, huge shuddering.I got to dock and called my diver who informed me my cutlass bearing was tight, but my once 3 bladed prop was now a 2 blade prop.(I must of over-cleaned the prop in dry dock).I puchased a new prop (same size/pitch) and the diver installed it. But there was stilll wobble in my stainless 1" 7-year old shaft. I then split the coupling from my atomic 4 and backed the shaft off. I noticed that I could move the shaft any direction about 3/4 of an inch. I pushed the shaft back into place and everything seemed to line up very well. when I hand turned coupling and shaft there seemed to be wobble still.Questions: Could I have bent my shaft? Is there a way to check shaft/coupling squareness in the water? Should I have 3/4" play when shaft is de-coupled? Any advice would be greatly appreciated. THANKS
gpd955
Feb 22, 2006
1,164
Catalina 310 Cape May, NJ
Any chance the engine and shaft misaligned during the time it ran with the broken prop? Misalignment will cause a vibration that sounds like someone is banging on the hull with a mallet. The cutlass bearing may also be unevenly worn and may appear intact to a diver only able to see a limited portion of the bearing and maybe not get a good feel for any play that might be present. Have you checked with Don Moyer at moyermarine.com. When I had problems with my A4, he would answer any questions in the forums. He even got on the phone with me a few times and talked me through diagnosis and repairs.
If it's moving 3/4 inch inside the boat, there could be damage to the stern tube and/or strut. Think of how it's arranged: coupling, stern tube, strut with cutlass bearing inside the strut. Good luck.
