W
Walter McNeil
I have a strange problem that I have been chasing for several years. Here's the background. When I aquired the boat, it had a vibration at cruising speeds (~2500) that would shake apart the stuffing box. The vibration is not really apparent in the hull of the boat, but the shaft moved visibly. I initially suspected the usual offenders; engine allignment, prop bent or out of ballance or shaft bent. None of these were the case. Since then I have sent the prop (15"x1" 2 blade max prop) back to PYI for overhaul, had the shaft checked/coupling faced and replaced the stock Yanmar mounts with one grade stiffer. Still the vibration. When the vibration killed the V-drive I replaced the transmission and added a dripless shaft seal and a flexible coupling to compensate for any misalignment resulting from shaft loading (there is no static misallignment). With the new trans came a new longer shaft (almost 6'). I have been told that is borderline too long for a 1" shaft supported only by the coupling and the cutless.After all of this I discovered a twist. The vibration does not occur when the boat is tied to the pier, only when underway. This would suggest that the vibration is due to some interaction between the hull and the prop that is only present when the boat is underway (there is about more than 2" between the skeg and prop tips). Apparently this disturbance is hitting a resonant frequency in the shaft.I recently changed the shaft rotation from left to right handed to see if that would change the dynamic enough to aleviate the problem. There has been a reduction in the vibration, but it still shakes the stuffing box enough to allow some water to get past the lip seal.Now finally here's my question.Do you think the shaft is just too small and flexible, or should I be looking for another solution like a 3 blade max? Would stiffening the shaft possibly put a greater load on the prop strut?I could go to a 1 1/8" shaft without redesigning the boat, 1 1/4" would be tough. Could increasing to 1 1/8" add enough stiffness to make a difference?I do not want to buy a 3 blade prop.Thanks,Walt
