I have an S2 8.0c that I am rebuilding. The inside plate and nuts were rusted. I removed them and will replace the steel plate with a SS plate and the nuts with SS nuts. The bolts are SS and look in good shape.
There is a ridged bushing inside the hole where the shaft goes through. It looks plastic, but may be something else. The boat has not been in the water for 10 years and this bushing is dried out and marred. (see picture) Does this bushing need replaced or is this normal? If replaced, where do I get one? What exactly is it called? Are there any tricks to replacing this bushing?
Also, what sealant should I use when I reinstall the strut to the boat?
